Newbie - Headlight Condensation
Old 12-18-2006 | 01:56 PM
acs4ny
Default Newbie - Headlight Condensation
Hey All,
Have only posted once before, so am still pretty new. Anyways, I've got an 02 accord coupe that I absolutely love. I recently replaced the blub in the driverside headlight with a sylvania silverstar and it looks great. Only problem is that there's now condensation buildup inside that headlight only. I checked to make sure all was tight but couldn't find a leak anywhere. Only thing I could posisbly think of was the thread on the silverstar used to twist into the headlight was a bit shaved off on one corner -> but didn't look like enough for air/water to pass through. Looked through some previous posts/FAQ's but couldn't come up with a resolution, any ideas where to check? hate to buy another $30 bulb but will i have to, or can't figure it out Thanks....
Old 12-18-2006 | 02:58 PM
Default RE: Newbie - Headlight Condensation
New bulb won't fix it. You have to remove the moisture from the housing.
The bulb should have an O-ring or something like that for a seal. The threads themselves don't need to be airtight.
It's a pain to remove the headlamp assembly from the car. But that makes it easier to dry out the housing. There should be a small vent somewhere, but where the lens attaches to the rest of the housing should be watertight. Maybe you could trysome caulking around that area??
Old 12-19-2006 | 07:53 AM
EMEX's Avatar
is the head light dot and sae approved. maybe it was changed during an accident for example and did not have the certificates. that's a common problem with aftermarket head lights.
Old 12-19-2006 | 03:04 PM
ArcticHonda's Avatar
I took a rock to my left light and it has a small crack in it...i think thats where my condensation is coming from anway. Maybe a junkyard trip is in my future...
Old 12-19-2006 | 04:00 PM
sir_nasty's Avatar
There are lots of headlights on e-bay that are dot/sae approved for fairly cheap... I'd say less than $100.00 you can get two aftermarket headlamps.... The crack may very well allow the condensation to occur
Robbie154
10-02-2010 12:43 PM
Will14
01-08-2009 08:43 AM
Robcie
07-31-2007 01:22 PM
91boz
06-22-2007 07:16 PM
BostonPuppyDawg
09-01-2006 02:52 AM
