No fuel and no spark
Old 05-11-2011, 05:31 PM
Ratchison's Avatar
there wasnt power on any of the wires going into throttle position sensor.
Old 05-11-2011, 06:50 PM
Check the 7.5 amp backup/radio fuse in the engine bay fuse box. Also check the ECU fuse. Can't remember where that is located
Old 05-12-2011, 02:41 PM
Ratchison's Avatar
I replied to this once, i dont know why it didnt take. I checked all three wires on the cannon plug for the TPS. None of them have power going to them. I checked from the pin to a good ground on the block. Is the TPS suppose to have power at all times with the engine in "II"?
Old 05-12-2011, 02:45 PM
Ratchison's Avatar
Im not sure why the post i just put up isnt showing so ill type it yet again. I checked all three wires in the cannon plugh going to the TPS. i checked them going to a good ground on the engine block and none of them have any power at all. Does the TPS have power going to it all times with the engine in "II" position? And if it didnt have power to it would it prevent me from getting spark or fuel pressure?
Old 05-12-2011, 02:48 PM
Ratchison's Avatar
sorry didnt see your post before i posted the last. I will double check the fuses but they were all fine before.
Old 05-12-2011, 04:02 PM
The reference voltage to various sensors like EGR, TPS, MAP, etc.. get the power from the ECU. You can try to check for the proper voltages at other sensors.
You may want to check the connection to the ECU as well. Maybe you have a loose pin(s)? It is possible to have a bad ECU as well.
90snowman
01-27-2024 10:26 AM
live2rice
08-08-2021 04:20 PM
BigOBob
01-01-2012 02:47 PM
samsungd838
05-14-2011 08:19 PM
fastdart360
01-25-2008 09:19 AM
Quick Reply: No fuel and no spark
