No heat or a/c, but blower works?
Old 11-14-2010 | 08:36 PM
VAaccord's Avatar
Default No heat or a/c, but blower works?
Here's my problem. On my daughters '99 Accord LX. The blower works great but the car will not produce heat or a/c. The buttons do not work and will not light up. Called the dealer, they said the a/c control panel needed to be replaced, said about $410 bucks. I need the experts on this forum to help me out. Is the dealer correct? I sure hope not. $410 bucks, really?
Please help. Thanks in advance.
Old 11-14-2010 | 08:51 PM
It may very well be the heater control unit (panel). You can find used one on ebay for around $100 or try a salvage yard.
Here's one that will end pretty soon. Just an example:
http://cgi dot ebay dot com/ebaymotors/98-99-00-Heater-Control-Unit-Honda-Accord-w-AC-OEM-LKQ-_W0QQcmdZViewItemQQfitsZModelQ3aAccordQQhashZitem2 eb12bdc90QQitemZ200540937360QQptZMotorsQ5fCarQ5fTr uckQ5fPartsQ5fAccessories
Old 11-14-2010 | 08:53 PM
Instructions to remove are here:
www dot ledautomotive dot com/guide.php?id_cms=14[/url]
Old 11-14-2010 | 09:07 PM
VAaccord's Avatar
Thanks redbull. Is that the name of the part, Heater control panel?
Old 11-14-2010 | 09:15 PM
Heater control assembly or heater control unit. When you search ebay, use something like accord heater control unit.
Attached Thumbnails No heat or a/c, but blower works?-heater-control-assembly.jpg   No heat or a/c, but blower works?-heater-number.jpg
Old 11-14-2010 | 09:50 PM
Suggest pulling old unit and inspecting all connections carefully. These are pretty simple components and whole thing being dead smacks of system being disconnected electrically, rather than defective.
Old 11-14-2010 | 10:05 PM
VAaccord's Avatar
Is there an actual circuit board in the control panel that can be replaced?
Old 11-14-2010 | 10:29 PM
There is a circuit board, see the ledautomotive link above. You can try touching up the solder points too.
techie768
12-08-2014 08:35 AM
redbull-1
08-10-2014 01:06 PM
jlpatterson
12-09-2013 07:25 PM
smitty2919
12-16-2012 11:21 AM
njjoe
10-30-2011 11:54 AM
