no keyless entry after replacing multiplex unit
2005 Honda accord ex, 4door. So i replaced the multiplex unit on the drivers side door now might keyless entry won't work. How do i fix this?
I plug my old on back in and the keyless entry works just fine.
Why replace MICS?
MICS requires diagnostics similar to ECM, find code, and address code issues. You will need a shop manual to perform the diagnostics w/o special honda tool. check automanualsource.com for an download manual.
It may be as simple as new key replacement process, however this requires special tools that locksmith and Honda only have.
After replacement of the door multiplex control unit, you'll have to reprogram the remotes. See post #8 in this thread link:
https://www.hondaaccordforum.com/for...78/#post320458
Billyp
02-13-2011 06:25 PM
