No start 92 Accord
No start 92 Accord
I have a Accord that I received from a friend ,the car sat since 07 .I have replaced the injectors .tank ,lines and filter and the car ran well for about a week . Now I have a no start issue I trouble shooted a distributor issue with the manual and codes replaced the distributor along with the coil . Still no change it has spark at each plug long with about 40 pounds of fuel pressure also checked the main relay . Any thoughts out there on what next....first time posting here
I'd start with the simple stuff first. Look at the distributor cap from the passenger side of the engine bay. Find the spark plug wire that goes to the #1 cylinder (closest to driver's side of the engine bay). The next spark plug wire going clockwise should go to #3, next is #4, and last is #2.
It is possible to install the distributor 180 degrees out of time (guess how I know?). Do you know how to get the engine to top dead center?
