No Turn Signals
RE: No Turn Signals
if somehow the water shorted out the circuit then it possible it could have fried that circuit in the ICU (integrated control unit). I have seen this before, same sympton where turn signals don't work, but hazards do, etc. ICU is pricey too, over $200 back then when i fixed it.
RE: No Turn Signals
i ran into a simalar prob last week, in my case it was the flasher dash switch (all you wiring runs thru it) mine would engage but not dis-engage, my flashers worked while my blinkers did not, like i said similar, make sure the hazard switch is working properly, mine was easy to get to because i have the radio out. I found the swich at pull apart for a dollar, 52 from honda, good luck.
RE: No Turn Signals
Thanks to all for the help. I am going to start by completing the circuit. I orderd
a new bulb boot??? I think its called from the dealer friday ($8.95) but it wont be
in untill mon at the earliest. I will keep all posted when I replace that.
