No turn signals when I turn headlights on
Hello and thanks for your time to try and help me I've got a 2007 Honda Accord 2dr ex other day I get into it to go somewhere and was pulling out of my street and had turn signal on and turned my headlights on and my signal quits flashing or working at all but my left indicator light on the dash come on and stayed on as long as the headlights is on my right one does not come on or work also but I later noticed after I turn my headlights off and just turn the turn signal on every light on the dash just about flashes and I've looked grounds and changed flashers both already and still nothing can somebody help please.
Yes turn signal flash
Yes my turn signal / properly with the headlights off with the exception of the rest of the dash lights radio interior lights the instrument cluster lights everything else just flashing every time the turn signal with the headlights off
Your description sounds like a ground issue to me. How did you check grounds?
There are 4 ground locations. The two on the front are below the headlights. There are two grounds in the trunk of the car, one on the driver's side near the rear window, and the other on the driver side near the the rear light assembly and the trunk opening.
