noise while turning and vibration
I had pervious post regarding noise coming from tyre while tuning( for few km)only when its cold outside. i went to hond dealer he said it could be bearing making noise. is it possible that bearing give problem at 101k? i also had problem of vibration when radiator fan kicks in. i found that its now regular it only vibrates some time really bad(could see dash vibrating). i dont now if its rpm or something else like engine mount? but i once saw it doing 650 rpm at idle in drive. but it mostly do 700 rpm when i turn on defogger. Can you guys advise me what to get checked as dealer charge a lot if you just tell them to check front end. how to you check front engine mount?
________
Mercedes-Benz Museum
________
RE: noise while turning and vibration
to check an engine mount you're basically just looking for either loose nuts/bolts on them, or cracked/worn rubber... Sounds more like an idle issue, when you turn on the A/C does the idle drop drastically? When the car is sitting at a stop in neutral what does it idle at?
Today it was vibrating but idle was at 750 rpm it stays here in gear or in neutral. my goes nearly at 10 km/h without having to press accelerator. i think its little fast i dont know if its like that in all accords. also i had two new engine mounts rear and driver side. they were broken before i bought it. could there be some thing misaligned in engine which cause this vibration.
________
Huge **** Webcam
________
Huge **** Webcam
huhdo
08-30-2012 10:06 PM
