obd II code
Old 02-22-2007 | 12:05 AM
blackex19's Avatar
Default obd II code
P1164. .what can be possibly wrong. . .[:@]
Old 02-22-2007 | 12:56 AM
hondadude's Avatar
Default RE: obd II code
Primary oxygen sensor out of range; is it screwed into the header?
Did the problem happen rightafter any of the Mods were done?
Old 02-22-2007 | 04:02 AM
blackex19's Avatar
i have dc sports headers installed. .a couple of months after i got the headers on my cat converter went out (cracked inside) and i put in a high flow cat in with brand new oxygen sensor. . recently my "CEL" has been coming on and off. .it had been a while since it went on so i decided to check out the code and p1164 was what it gave me. .the sensor is in the header
Old 02-22-2007 | 04:18 AM
deserthonda's Avatar
chk the connection and the wiring if all is ok you might have to replace the sensor....did you install the oem sensor? or the one where you got to cut and splice the wires to the original wires + connector
clear the code and see if same code comes up again first ..
Old 02-22-2007 | 04:28 AM
blackex19's Avatar
connection and wiring is fine. .oem sensor was installed (the one that goes in the cat converter). .this is the first time this particular code has come up so im assuming that it would be the o2 sensor since it has not been replaced to my knowledge. .bummer
Old 02-22-2007 | 04:29 AM
blackex19's Avatar
something i did not mention was that before the 'CEL' came on i had added the techron fuel cleaner stuff that's supposed to be safe with the sensors. . .
sooty305
07-06-2012 08:14 PM
dragonle87
10-05-2009 10:53 AM
dragonle87
10-04-2009 09:54 PM
Treaddirt
10-09-2006 02:10 PM
Treaddirt
06-14-2006 12:00 PM
