Odd problem...
Ya definitely the gas gauge. Now its not starting and the gauge dropped to e again.
Around 130k miles. But the fuel pump would affect the gas gauge?
Alright so I went in and removed all the carpet and everything from the back. Found a ground that looked disgusting and was a little loose. I'm assuming that this is the ground for the Fuel Sending Unit. So cleaned it up and sanded down the area. But the ground back on and I hear the fuel pump come on when I turn the key and the gas goes back up. So far everything seems to be working normally. Anyone have any thoughts on this?
#17
Cross your fingers & hope it's fixed. A bad ground can certainly cause both the fuel gauge and fuel pump issues.
Main relay could've caused the fuel pump issues, but not the fuel gauge. Pics are a bit out-of-focus, but you're looking for tiny hairline cracks in any of those solder joints on the circuit board. If you're good with a soldering iron, you could re-melt all of em anyway, just for grins.
#18
#19
fuel pumps many times now come as assemblies and in these assemblies are incorporated the fuel level sender.
if you found that it was a loose connection, then you have possibibly found your problem. Yah Yah! I hope this is it, cause it saved money!
an intermitten electrial supply can cause the same symptoms as a fuel pump going bad.
#20
