Oil Change after Techron use?
Hi All,
I plan to use Techron Concentrate in my next fill-up. I remember hearing one should then change theengine oil after the second tank of gas. Is this true? why?... is it because somewhat the fuel/additive gets into the oil?
... thanks in advance.
RE: Oil Change after Techron use?
I don't always do it. I think the reasoning is that the Techron is more likely to wet the cylinder walls & from there get into the oil. I bet most of it burns up, but I haven't done any oil analysis to prove that.
ORIGINAL: crvone
Hi All,
I plan to use Techron Concentrate in my next fill-up. I remember hearing one should then change the engine oil after the second tank of gas. Is this true? why?... is it because somewhat the fuel/additive gets into the oil?
Hi All,
bloopers
10-09-2014 09:31 AM
PinkFloridaFlamingos
08-24-2011 01:35 AM
KincaidChance
05-03-2011 02:13 AM
