oil leak
#19
Desertmike had a good point about the rear balance gear seal? Its the gear that you lock in place with a 1/4 inch drill bit from an access port behind the engine block. It does not look like this seal was part of the kit you bought.
Also, did you install a front balance shaft seal retainer?
You may want to inspect the back of the engine to make sure that the oil filter or the oil pressure sending unit are not leaking oil.
If you can't find the source of the leak, you may have to remove the timing belt covers to try and find the source of the leak from those seals. I know it sucks, but those sound like possible culprits.
