Oil Leak -FYI
Oil Leak -FYI
I just had to have done on my 1996 Hond Accord EXL 4Door sedan
1. Replaced Valve Cover Gasket
2. Timing belt
3. Balancer Belt
4.Oil Seals and Oil Pump Seal
5. Oil Pan Gasket
for $1100.00 Keep in my mind if you have an oil leak this where it usually starts, mine was on the left side of the car and stained my driveway really good.
2. Timing belt
3. Balancer Belt
5. Oil Pan Gasket
RE: Oil Leak -FYI
ORIGINAL: MichaelEXL
2. Timing belt
3. Balancer Belt
5. Oil Pan Gasket
2. Timing belt
3. Balancer Belt
5. Oil Pan Gasket
sounds like the balancer shaft seal was leaking very typical on 94-97 accords
RE: Oil Leak -FYI
unless you live in NYC, I think I just passed out.......then I saw oil pan and most likely front and rear main seals and then figured it was OK price
that is what you meant by oil seals right?
RE: Oil Leak -FYI
ORIGINAL: YeuEmMaiMai
to replace the oil pan gasket ,, a shop should charge no more than 2 hrs in labor ......a flat rate tech can go it in 30- minutes or so.. ( easy money..)
i doubt that they replaced the rear main seal ,, if they did than i stand corrected the price is good .. BUT i am willing to bet that they did not
RE: Oil Leak -FYI
Slightly off topic (but it seems like a good time to ask) - how long does the rear main seal last on a 92 Accord LX 4AT? (Now there's a job that I'm willing to bet is going to take more than an hour or two!)
RE: Oil Leak -FYI
ORIGINAL: Tony1M
mm it will take longer than a few hrs , tranny needs to come out ..
