Oil overfilled? what to do?
Old 08-10-2006 | 05:31 PM
ufoforever
Default Oil overfilled? what to do?
I have a 97 accord se without vtec. I just got an oil change, and when the engine is off and fairly cooled down, the dipstick reads a little bit above the last dot or perforation on the dipstick. I am guessing it was possibly overfilled no more than a half quart. Its Mobil 1 syn 5-30 oil if that makes any difference. This isnt my first car, though it is my first honda/japanese car, and it has no leaks, and no obvious problems, and 170k miles, and I need it to last as long as possible.
How much overfilling of oil will warrant a problem or leak?
If this is a potential problem, how would I deal with this? Undo the drain plug, or what?
Please help. Thanks in advance.
-Scott
Old 08-10-2006 | 06:40 PM
deserthonda's Avatar
Default RE: Oil overfilled? what to do?
that little of an overfill is not going to cause any problems,,,,,,,however if you want to drain some, remove the drain plug and drain a little bit
Old 08-10-2006 | 07:47 PM
Chiovnidca's Avatar
I wouldn't worry about it.
Old 08-10-2006 | 08:19 PM
mbo1985's Avatar
Yeah, don't worry about that. It'll be fine.
Kudos for keeping a close eye on your car's levels though. That's the kind of foresight that catches problems before they start.
MessAround
04-18-2013 05:33 PM
MiyashiMeism
09-05-2010 02:12 PM
humblehyper
11-12-2008 08:36 AM
therivler1
01-22-2008 10:47 AM
vistin
08-13-2006 02:49 PM
Quick Reply: Oil overfilled? what to do?
