oil pan gasket replacement sealant
Old 06-05-2014 | 02:57 PM
tdsilk's Avatar
Default oil pan gasket replacement sealant
Hello,
I have a 2001 Honda Accord EX 4cycl and I just removed the oil pan.
This is the original oil pan and it looks like it only had sealant to secure
it. It also appears that sealant was on the bolts. My question is whether
I should use a rubber gasket and a little sealant on the corners or just the sealant only? If the sealant only what type is recommended?
Thanks Much!
Troy
Old 06-05-2014 | 07:27 PM
Roader's Avatar
On the advice of others on this forum, I just went with sealant and, two years later, no leaks. I used red high-temp Permatex, letting it "skin over" for 20 minutes or so before putting the pan back on.
Old 06-05-2014 | 08:29 PM
Shop manual calls for a gasket.
Liquid gasket material (RTV) is only called for at the corners of the circular section on one end. You might use a tiny amount of RTV to secure gasket to pan for handling purposes.
Old 06-05-2014 | 09:30 PM
tdsilk's Avatar
ok. Thanks.
Old 06-07-2014 | 10:44 PM
tdsilk's Avatar
Ended up adding the sealant only. I haven't check for leaks yet, because I'm having a bit of a problem getting the last bolt on. It's corner bolt that's on the driver side near the timing belt. It's a pita to get lined up to start the thread. Are there any deep dark secrets to getting this thing on? So far I tried a 1/4 inch ratchet w/ a 10 mm socket.
Old 06-08-2014 | 07:41 AM
Roader's Avatar
No secrets. I don't recall anything in particular being in the way to start that bolt. 1/4" drive is the way to go.
File Type: pdf
Old 06-08-2014 | 09:00 PM
tdsilk's Avatar
I was able to get the bolt in with an angle socket. I guess having the right tool is everything:-) Thanks for the help.
Old 06-10-2014 | 05:27 PM
Glad you got it and thanks for the follow up.
And yes, I can't even tell you how many little, odd tools I have in the garage just for doing "X". Example, I got a ~20 inch long #2 phillips screw driver, why - just so changing the bumper turn signal bulbs on a fith gen Accord is a sanp - in and out in less than five minutes.
ccookie66
04-12-2019 04:43 PM
MikeT
03-05-2015 07:12 PM
frost506
01-16-2012 07:21 PM
tjl695
05-14-2009 03:05 PM
mcrisost1999
07-10-2005 07:13 PM
Quick Reply: oil pan gasket replacement sealant
