oil rocommended for oil change
Old 06-04-2008, 12:23 PM
crvone's Avatar
Default RE: oil rocommended for oil change
Mostly Mobil1 5w-30 and Honda filter, last oil changeIswitched to Mobil1 5-30 Extended Performance and Mobil1 Oil filter.
I do hear good things about Pennzoil Platinum and might give it a try next time.
  #22
Old 06-04-2008, 01:09 PM
klrspz's Avatar
I just use a plain jane fram filter... might check out the mobil1; any benefits?
  #23
Old 06-05-2008, 11:17 AM
drummer1279's Avatar
fram are S**T. cardboard and glue. Mobil 1 or K&N oil filters would be the absolute best to get that are commercially available. both have over 99% multi pass efficiency.
  #24
Old 06-05-2008, 11:41 AM
ford's Avatar
btw, what is the difference between 10W-30 and 10W-40?
  #25
Old 06-05-2008, 11:47 AM
Each number is a 'weight' which is a kinda bogus way to refer to viscosity. It refers to an allowable range of viscosity measured at a certain temperature.
The 30 & 40 refer to the oil's viscosity at operating temperature. The first number with the "W" refers to it's viscosity cold.
So...
10w-30 & 10w-40 should measure about the same viscosity if you measured it cold. I can't remember if that's 0.C or what temperature.
But if you take those oils & measure viscosity at 100.C then the 10w-40 would have higher viscosity.
  #26
Old 06-05-2008, 01:31 PM
klrspz's Avatar
Actually, I was at VatoZone while my wife was at WalMart, and 1 to 1 all the way, Walmart was almost consistently 50% cheaper.
I now buy my filters and oil at WallyWorld
  #27
Old 06-05-2008, 02:23 PM
falkore24's Avatar
ORIGINAL: JimBlake
So...
The #'s themselves are relative to crude oil at the 2 temps (40.C &100.C per a website that I just looked up .... 40 seems high, 104.F). They are percent of the crude viscosity.
  #28
Old 06-05-2008, 09:18 PM
ford's Avatar
i still dont get the viscosity...for ex. i live in florida and it is most of the time warm if not hot everyday...what would i pick between the 10W-40 or 10W30?
  #29
Old 06-06-2008, 09:56 AM
10w-30 is your best bet or 5w-30 the oil passages in Hondas are very small, so using anything higher than 10w-30 will be risking damage to the motor. As for shopping at WallyWorld to get oil and filters....its your cars death...yea the oil is cheaper but the filters are crap and you are supporting a growing global monopoly.
  #30
Old 06-06-2008, 01:25 PM
ziwang55's Avatar
well does anyone have any data based on the oils performance in a chart or some sort
62maxx
10-18-2015 08:20 AM
KincaidChance
05-03-2011 01:13 AM
chris h
04-03-2011 10:01 AM
62maxx
11-21-2006 12:04 PM
Quick Reply: oil rocommended for oil change
