oil soaked plugs
Old 01-10-2010 | 10:00 PM
riverman's Avatar
Exclamation oil soaked plugs
i have a 93 accord 2.2 L with 183K miles. went to change the spark plugs and found that all of them are soaked with oil. hoq can this happen and how can i fix it?
Old 01-11-2010 | 11:01 AM
That's the sparkplug tube seals, basically that's part of the valve cover gasket. There's already some threads about that.
Old 01-11-2010 | 08:13 PM
riverman's Avatar
thank you i will read
Old 01-11-2010 | 08:25 PM
EXV6NIGHTHAWK's Avatar
Hopefully, it's not the o-rings under the rocker arm assembly. Those are much harder to change. If you look down the spark plug tubes, there are two seams. One for the valve cover seals, and one for the rocker arm assembly.
Old 01-12-2010 | 08:04 AM
Yeah, exactly. I'd change the upper seals & cross your fingers. If it still leaks, then removing the valve cover AGAIN is a very small amount of duplicated work.
Old 01-12-2010 | 10:27 AM
riverman's Avatar
Ok, how hard would it be to do it all at one time?
Old 01-12-2010 | 11:00 AM
Not much harder than doing it separately. All the real work is removing the valvegear & camshaft bearing caps. That's why you can try the valvecover gasket first. Repeating the work of removing the VC is trivial.
Old 01-12-2010 | 02:14 PM
deserthonda's Avatar
there is a step by step in the DIY section........here you go
https://www.hondaaccordforum.com/for...ead.php?t=3088
Old 01-13-2010 | 10:35 AM
riverman's Avatar
Thanks guys, looks like a day of research and read for me.
Tony Frattle
06-29-2012 10:38 PM
wannakeepmy94Accord
03-14-2012 09:06 PM
9foaccord
06-13-2011 08:45 PM
mfre1111
02-07-2008 11:44 AM
hotrod20
12-05-2005 12:04 AM
