Oil Under Hood
Old 11-29-2006 | 08:06 PM
daddy's Avatar
Default Oil Under Hood
94' Accord Lx - Manual
Today when I raised my hood to fill my clutch fluid up, I noticed oil on the inside of the hood. If the hood were closed it would line up directly with the timing belt area. Would this be an indicater of a leaky valve cover gasket or more serious? The car runs great and I have no motor trouble at all.
peace out,
daddy
Old 11-29-2006 | 08:15 PM
deserthonda's Avatar
Default RE: Oil Under Hood
TAKE A CLOSE LOOK AT THE P/S PUMP I BET THE FRT SEAL IS LEAKING
oops caps..........put your finger under the p/s pump pulley CAR OFF OF COURSE .. if it is oil wet frt seal is leaking .. need to reseal pump.......
Do not let someone tell you to replace the pump,, Honda sells a reseal kit 15-20 dolars , the rest is labor ,, 1.0-1.5 hrs
Old 11-30-2006 | 04:37 PM
daddy's Avatar
Thank you sir...I will give it a look over :-)
peace out,
daddy
Lovemy97HondaAccord
03-05-2014 07:04 PM
MessAround
05-24-2013 09:42 PM
Pickrng
06-22-2010 01:54 PM
dtycoon2003
08-11-2006 09:29 PM
boo623
07-09-2005 08:30 PM
