Only Honda ATF?
Old 07-09-2007 | 03:15 AM
lgetz's Avatar
Default Only Honda ATF?
High to all. I recently purchased an 02 EX 4cyl. w/ an AT. I haven't driven the car but 20 miles because it needs a few interior pieces. The car is a solid 8.5 looks wise. My question is do you all only recommend Honda brand ATF? Can I not use a Castrol brand at Advance Auto that states it is compatible? Don't mind spending the $$$ but only if really necessary. BTW I did a search and came up empty but plenty of vets stated "use only Honda ATF." Thanks in advance. (No pun intended)
Old 07-09-2007 | 06:37 AM
Default RE: Only Honda ATF?
All you can find will be reports that Honda ATF improved shift performance and corrected minor trans problems. You only need to change every 2-3 yrs, so not a major expense. I used Walmart ATF for several years in my 90 Accord w/o problems until I became a convert to Honda ATF. No particular reason except the testimonials were compelling.
Old 07-09-2007 | 07:39 PM
lgetz's Avatar
OK. Thanks TX Honda. I went and bought genuine fluid at the dealer. Not bad 3 qts. were about $18 dollars. Will be performing the change myself.
Old 07-09-2007 | 07:58 PM
hondadude's Avatar
The biggest reason for Honda ATF is the smaller lubricating molecules.
The shift valves fit into the valve body with no seals, just a very tight fit to the bore.
Cleaning properties come into play as well, any varnish build up will cause the shift valves to bind a little and shift slower.
Old 07-10-2007 | 01:17 AM
lgetz's Avatar
Well I got the tranny fluid changed. The old fluid was light reddish brown. Didn't seem too bad but I wanted extra piece of mind. BTW took a 30-35 mile drive and everything seemed well. Now as soon as I get the inside put together this will be the daily driver. Thank you both TX Honda & HondaDude.[sm=shades.gif]
curtie94
06-23-2012 08:52 PM
moey
05-22-2011 11:43 AM
markrb
01-28-2011 12:25 AM
dknight211
01-22-2008 07:35 PM
brave_mhy
06-29-2007 11:34 PM
