Overheating
...Cooling fans come on as they are supposed to while driving...when I turn the car off, I hear the radiator always pissing in to the overflow tank, so eventually lose coolant. The fans turn off when I turn the ignition off, even when left in the accessory position. If I turn the ignition switch back to on position after turning engine off fans will run until engine cools...
Fan switch A is located in the thermostat housing. It switches the fans (both) when the engine is running. Pretty sure that works when the key is turned ON but the engine doesn't actually need to be running.
Fan switch B is located in the nozzle for the upper radiator hose, near the head. This one has authority to switch one of the fans, after the engine has been turned off. There's a timer to prevent the fan from running forever even if the switch-B is stuck.
I was losing about a quart every 200 miles, with no other typical bad head gasket symptoms. If the sensors end up being good, you may want to try pressurizing each cylinder at TDC to see if water gets pushed out of the open radiator fill.
Overheating
Thanks guys, Have been running with sensor B jumped and have had no problems at all. Flushed system and put proper 50/50 coolant mix and have not lost a drop since fans turn on after I shut off engine. Will invest in a sensor soon so I do not have to listen to the fan all the time.
