Oxygen sensor issue
Oxygen sensor issue
Hi everyone. I have a 2006 Honda Accord V6 AT from NYC. This weekend the check engine light came on. It's reading a "P0134" code with the AutoZone scanner tool. Can someone please tell me which sensor this is and maybe send me a diagram if possible? Also, if this easy to change or should I take it to the shop/dealer?
Thank you everyone..
On the exhaust manifold back against the firewall, #9 is the sensor you want. Not sure, but it might be tucked back under the ventilation cowling??
Unplug the wire for that sensor & find the 2 same-color (black?) wires from the sensor. Measure resistance between those wires. Not sure what it's supposed to be, but a failed heater normally shows open-circuit.
If that heater element is OK then you're looking for problems in that circuit like maybe blown fuse or cut wire.
