P0420 bank 1 2007 Accord EX-L v6 3.0
Hi there,
I acquired a 07 Accord EX-L v6 @73k miles a few months ago which currently has 75k miles on it.
Things have been going good but now it's throwing an active P0420 catalytic underperform bank 1 code with no other active or pending codes. It came on during freeway driving and I am using 87 octane gas. It took a bit of googling to finally figure out that bank 1 is the rear engine warm up cat.
I have seen a youtube video where a mechanic uses a higher end code reader to graph live o2 sensor voltages for troubleshooting but I don't have access to anything like that.
Is this something I can fix in 3 months or do I have to fix it immediately?
Thank you
Thank you
Hi there,
Thank you
Thank you
How's you fuel mileage?
Do you have emissions testing in your state? Is that the reason for wanting to wait? It's usually 1 or the other, as for an O2 code, bad O2 sensor, or bad cat.
Current gas millage is about 18-19 mpg city and last time i went on a trip I got about 32-33 mpg hwy.
However, I have not checked the oil in 3 months as I don't drive the car very far and I discovered it is already on the low side of the dipstick range(so basically its low on oil). This car has burned a bit of oil over the past 1500-2000 miles. Then again, that could be faily normal oil burning, I don't know, but I think it burns more oil than my 97 honda civic.
I guess I should put extended millage oil in this car from now on? It could also explain why the car is throwing a cat code.
snoopy4369
02-27-2015 07:30 PM
