P0420 & ECM/PCM Update
Old 05-02-2014 | 09:52 PM
R.A.D.'s Avatar
Default P0420 & ECM/PCM Update
Has anyone gotten code P0420 and then had it cleared up by getting their ECM/PCM updated as per the TSB related to this issue? Before I start spending money on this problem, I wanted to know if anyone was successful in getting rid of the problem via the update.
Thanks!
Service Bulletin A04-063
Applies To: 2003 Accord L4 except SULEV – ALL
2003 Accord L4: MIL Comes On With DTC P0420
SYMPTOM
The MIL is on and DTC P0420 (catalyst system
efficiency below threshold) is set.
PROBABLE CAUSE
The ECM/PCM may incorrectly interpret sensor inputs
and set DTC P0420.
CORRECTIVE ACTION
Update the ECM/PCM software using the Honda
Interface Module (HIM).
Old 05-02-2014 | 09:54 PM
The service bulletin is only applicable to the 4 cylinder.
Old 05-03-2014 | 12:39 AM
R.A.D.'s Avatar
Damn! Thought I was on to something. Thanks for the heads up.
rbrunner
07-03-2017 11:31 AM
Brad6251
03-06-2014 04:45 PM
ssuh
03-27-2012 09:10 AM
southernboagurl
06-02-2009 07:22 PM
blazinfnestyle
03-19-2007 07:02 PM
