P0420 and P0430 codes
Old 05-12-2019, 11:59 AM
djjazzyjeff's Avatar
Default P0420 and P0430 codes
Hey Everyone:
I have a Accord that has 180,000 m on it and I've been getting the two P0430 and P0420 codes on it. 2 mechanics I took it to fell that that cat's the problem but I just want to get some other opinions before I invest in a new cat.
Thanks.
Old 05-12-2019, 12:41 PM
The Toecutter's Avatar
Originally Posted by djjazzyjeff
Hey Everyone:
Thanks.
Usually the P0430 code is either the cat, or rear sensor. Not sure what the P0420 code is. What year is the car?
Old 05-12-2019, 02:18 PM
P0420 is for the front bank catalytic converter, and P0430 is for the rear bank converter. Both are that the catalyst is below threshold. I'm guessing this is a V6 accord?
Are there any other codes, or previous work done on the car?
Is this constantly happening over several tanks of gasoline, or did the check engine light turn on after say filling up the gas, or any work done on the car?
Old 05-13-2019, 03:38 PM
Thanks PAhonda. I wasn't sure if the P0420 was the front O2 sensor or not. Ive never had that code come up. The P0430 code yes. And everyone suggested replacing the O2 sensor, but instead I replaced the cat and used my old O2 sensor. It's been fine for over a year now without that code. I guess my old (non-stock) cat was bad.
Old 05-16-2019, 09:17 PM
1) Yes it is V6 Accord
2) No there aren't any other codes
3) Yes the code is constantly on. I've noticed my fuel economy is very poor.
Old 05-17-2019, 03:09 PM
The poor fuel economy is related to the P0420, as that's the upstream sensor (or fuel mix sensor).
Old 05-17-2019, 04:59 PM
I wouldn't make the call on the upstream O2 sensor based on the current information. The next step would be to monitor the fuel trims to determine how the engine computer is adjusting the fuel to manage emissions.
Old 05-17-2019, 05:29 PM
P0420 and P0430 are related to the separate primary catalytic converters. The 7th gen and 8th Accord V6 has 3 converters, the codes relate to the primary converters (bank 1 and bank 2) shown in the attached pic.
Each primary convertor has separate up stream air/fuel ratio sensor and downstream oxygen sensors; respectively. So, it is unlikely to be due to one sensor or the sensors. On these generation Hondas, it will most likely be due to bad cat converters.
Although not normal for both primary converters to be bad, it is possible. Does the car burn oil? If the car burns oil, etc., it may have caused both primary converters to become bad.
Old 05-20-2019, 09:39 AM
The car doesn't burn oil that I know of. It is pretty old, however.
Old 05-20-2019, 05:54 PM
Can you provide us more information about your car? The year, transmission, LX,DX,EX trim?
Quick Reply: P0420 and P0430 codes
