P1456 - Just changed my gas cap, that wasn't it
Old 08-30-2012 | 08:47 PM
Originally Posted by my1st.honda93
ok now im back,so what is the code saying?in english not numbers an we will find your solution
The code is saying almost everything you need to know - English/Spanish/French, ect.......
Old 08-31-2012 | 01:19 PM
I much prefer the code NUMBER. Sometimes the guy at the car-parts store can come up with some pretty --umm-- CREATIVE explanations.
Old 01-07-2013 | 04:56 PM
CEFIRO's Avatar
Originally Posted by LordAccord
I do live in the northeast, in NYC to be exact, but this car was purchased in Florida then driven back. I've had Autozone and Advance do a error scan, and always the same result. Both in Florida and NY. I also notice that when I drive around, after 10 minutes or so I smell gas.
I got the same issue with the smell too. I am looking foward to hear if you fixed it and how,
Thanks!
Old 01-07-2013 | 06:03 PM
shipo's Avatar
Thanks!
Pretty much regardless of make or model, when you smell gasoline vapors then the issue is with the Evap system; either the cannister or the hoses are cracked and/or deteriorating.
Old 01-08-2013 | 06:08 AM
LordAccord's Avatar
Thanks!
It turned out I needed a new EVAP canister and bypass shut-off valve. Both were leaking. I figured this out by getting a smoke test done at Meineke. Hope this helps.
93Accord2.2
11-07-2013 12:53 AM
96FiveSpeed
06-12-2013 01:05 AM
Hondafan454
05-23-2010 08:40 PM
phydeauxman
09-16-2009 07:36 AM
Gary L
10-06-2008 05:27 PM
