P1705 engine code and flashing d4
Old 12-03-2014 | 09:58 PM
i4ex's Avatar
Default P1705 engine code and flashing d4
Hey folks, just had to share this since it took me all day to figure it out. I just finished replacing the thermostat and took my 2001 accord for a test drive. Once I got back I developed a check engine light (code 7) and a flashing d4 drive light. I took it down to Oreillys where they scanned the code and got a p1705 code (TCM gear position switch low input). I couldn't help but think I bumped a sensor or something since this developed right after working on it but after careful examination of the sensor I noticed the connection for the gear position switch is RIGHT UNDER the thermostat. I tried to take it apart but its a real bear especially when covered in coolant....duh!, Ok..got out the compressor and blew out both ends of the connector and everything is back to normal (had to reset the CEL). Easy fix if you run across this.
Old 12-03-2014 | 11:28 PM
Good deal.
This is more technical rather than the "new member intro" section where you posted. I'll move it.
Old 12-04-2014 | 12:01 AM
i4ex's Avatar
Default thanks
thanks Jim, had no idea that's where this posted.
hitechredneck
08-15-2013 09:14 PM
BruceHunt
02-17-2011 01:48 PM
MikeT
03-11-2008 11:25 AM
Tyltong123
10-17-2007 09:26 AM
