Parking Brake and TCS indicator come on.
Old 07-05-2008 | 05:46 PM
2003 V6
Default Parking Brake and TCS indicator come on.
Dear Accord Enthusiast!!
I have a 2003 accord V6.
I've bleeded my brkae system yesterday. the procedure is just like as is.(evacuate fluid reservoir and refill with new fluid and bleeding 4 wheels from further to closer))
After that, I recognized that the parking brake indicatro and TCS activation indicator came in.
I thought the level of brake fluid maybe lower than normal. so I bought a honda genuine brke fluid (heavy duty DOT3) and refilled. However those two indicator still won't turn off.
please let me know what do I have to do and what's the problem.\
Let me ask one more question about brake pads. I replaced front brake pads last month because of squealing sound (the brake pads still remain more thna half.). After replacing the pads,squealing sound didn't go away. What should I do to remove the noise?
The last moremiscellaneous question is about sprk plug. Have you ever heard about "Pulse spark plug"? Does it work?
Thank you.
I'm really waiting your precious answer. ( The first question is the urgent one)
Enjoy your ride!!!
Old 07-06-2008 | 11:16 AM
Default RE: Parking Brake and TCS indicator come on.
Hello New Member
Please post in the correct forum when you post.
Thank You for joining the forums...
Old 07-06-2008 | 04:34 PM
YeuEmMaiMai's Avatar
is your brake fluid level sensor working?
is your parking brake switch working?
to get rid of squeal usually one appliesanti squeak to the back of the pads and shims but a lot of time semi metallic pads squeak no matter what
Old 07-15-2008 | 12:41 PM
2003 V6
Dear Dude!!
Theparking brake switch works well and
After replacing brake fluid, the braking get pretty better than before.
I don't know whether the brake fluid level sensorwork or not.
Would you let me know how to check the sensor?
Thanks.
Old 07-15-2008 | 05:38 PM
falkore24's Avatar
D@MN HAF!!!
Old 07-16-2008 | 09:02 AM
Dont have to scare off the new guy...
https://www.hondaaccordforum.com/Sti..._128656/tm.htm
mamtsberg
09-10-2012 09:58 AM
DerekWildstar
06-19-2012 12:06 AM
asmerik
01-21-2011 02:38 PM
2003 V6
07-06-2008 11:16 AM
nrangerfan
05-20-2005 02:57 AM
