passanger windows problem
hi guys, another day means another problem...
for some reason, my front passanger seat window took about 20 seconds to close up from a full open...
any idea why and ofcause any way to fix them?
thanx guys
thanx guys
RE: passanger windows problem
I had that situation last month. Here is what I did.
Lube the rails, now the rails is not the horizontal line with cloth feel, but the ones perpendicular to the ground.
Then I took the door panel off or have it out enough where you can clean out the cloth like material I mentioned earlier.
I used WD40 at first, but had better results after applying lubricant
Hope it makes sense
Hope it makes sense
https://www.hondaaccordforum.com/m_77869/tm.htm
there ya go. it got moved.
RoXeTTeMaN
08-05-2006 03:22 PM
