passenger window won't roll up from driverside
Old 06-12-2011 | 01:17 AM
crvone's Avatar
Default passenger window won't roll up from driverside
On my 95 Accord I can roll down the front passenger window from the switch on the driver door, but when I press the switch to roll it up nothing happens (silence). The switch on the passneger door works fine (it lowers and raises the window).
Anybodey have similar problem, what was the fix?.. thanks in advance.
Old 06-12-2011 | 03:21 AM
The first thing I would do is put something like a light coating of silicone paste in the run channel to see if the channel is binding the motor.
Old 06-12-2011 | 08:02 AM
piggylover1985's Avatar
The master switch could be bad.
Old 06-13-2011 | 12:45 PM
draser's Avatar
Pass window switch, driver side? Try to get the switch loose, and check w/test light/meter if 12V gets out when you try to raise pass window.
djkurious
09-02-2013 04:20 PM
savoiu
08-28-2012 12:12 PM
92tealaccord
04-09-2012 03:25 PM
rubberducky101
02-17-2012 09:03 PM
brave_mhy
09-20-2007 09:55 PM
