PCV Catch Can Ideal I Had?
Old 01-19-2009 | 12:44 PM
roozoo's Avatar
Default PCV Catch Can Ideal I Had?
I had an ideal on a Oil Catch Can between the PCV Valve and the intake. I have not seen anyone recommend this and was wondering if a Oil Filter Relocation Mount would work well. Would it be too restrictive? I was thinking that the oil filter would work as a good baffled can. I know they are meant to let oil through but no more oil than goes through the PCV system I thought this might work good. It should how a vacuum and it would look like something that is suppose to be there. Route the hoses from PCV to Inlet and Outlet to Intake.
Old 01-19-2009 | 12:54 PM
finch13's Avatar
Default RE: PCV Catch Can Ideal I Had?
I have a Kobalt Water/Air Separator meant for air tools as a catch can and it works great. The tank holds about 70cc and only needs to be emptied about every oil change... theres a DIY tutorial on 6thgenaccord.com and it costs less than $20 to build.
Old 01-19-2009 | 01:24 PM
roozoo's Avatar
I have a Air tool Separator on it now and it catches a little oil but still lets a good bit of oil through.
Old 01-19-2009 | 01:27 PM
finch13's Avatar
Hmm... does it have the nipple on the bottom to drain the water?
Old 01-19-2009 | 01:45 PM
hondadude's Avatar
Minor amounts of oil vapor pulled in thru the intake are used to enrichen the fuel air mixture.
It was considered by the engine design/ECU control.
Depending on the year.....stopping the oil vapor flow completelymay have adverse effects on fuel consumption.
On the other hand, if oil is dripping out of the intake, that means excessive blowby from collapsed oil wiper rings, or other problems.
becact
03-21-2010 12:01 PM
doanutboi
07-06-2008 07:52 PM
finch13
04-23-2008 11:17 AM
PhagnaScotty
04-01-2008 11:30 PM
visu79
10-10-2006 04:14 PM
