PCV Valve, clear something up
Old 01-15-2008 | 12:27 AM
eric123's Avatar
Default PCV Valve, clear something up
I need something cleared up about PCV Valve. If I shake it and it rattles it's fine and doesn't need replacing?
91 Accord EX 5 Speed.
Old 01-15-2008 | 02:33 AM
Default RE: PCV Valve, clear something up
If you hear a clicking sound when you pinch the tube that is between the vavle cover and PCV with the engine running, then the PCV is ok.
You should check that there are no clogs in the hose/valve either.
1lowcaprice
02-09-2009 03:26 PM
crvone
10-04-2007 07:04 PM
ranst20
03-27-2007 12:04 AM
WhyNotFab
01-17-2007 09:45 PM
Shifty
09-22-2006 10:29 PM
Quick Reply: PCV Valve, clear something up
