plzzz help!!
Old 11-17-2009 | 10:32 PM
o CRA5H o's Avatar
Exclamation plzzz help!!
i went out to get my car out of the garage and go to the store near my house and i got in and tried to start it and i got all the normal lights and stuff like always but as soon as i turn the key further to start it i loose all lights on the gauge cluster and the light around the key is off. i turn the key back and try it again and all my lights are back, when i turn the key to step "2" i loose all lights again. i cannot get the car to start or crank or do anything for that matter. i have lights and everything on step 1 and nothing on step 2. there is a light that flashes when the key is in step 2 and it is the "security" light on the console near the climate control switches.
i do have an alarm system on it from the factory(not aftermarket)
is my problem a relay?
or switch?
fuse?
i really dont know what to do so any help or suggestions would be great.
Old 11-17-2009 | 10:51 PM
deserthonda's Avatar
chk the battery + cable,, make sure battery is fully charged and cables are tight and clean...if all ok. i would look at a possible ignit switch or alarm issue ,,,,,,,
i am more for an alarm issue ...
Old 11-17-2009 | 10:56 PM
Those accords didn't come with a factory alarm. Is the red light flashing on the radio?
Old 11-18-2009 | 12:42 AM
finch13's Avatar
My 1995 had a red led on top of the steering column that flashed from the factory. I find it hard to believe a battery would just die like that if it was driven fine for a few miles with no issues. At the very least, it would have a little juice and make the relays click like crazy.
Old 11-18-2009 | 01:54 PM
o CRA5H o's Avatar
i have found out that when this car was bought from the dealership it was a custom order....they wanted an alarm system on it. is there anyway to disconnect the alarm system without affecting anything else? yes the red light is flashing near the ac switches.
Old 11-22-2009 | 12:41 PM
o CRA5H o's Avatar
ok where would the alarm controller box be located? im going to see if i can unplug it and see if i can get it to start then.
does anyone else have any ideas for me to check or try?
JYok2247
08-30-2010 01:14 AM
mamtsberg
03-17-2010 10:15 PM
joshk5145
03-09-2008 10:00 PM
Ildiavolo
02-13-2008 02:50 AM
