possible DIY?
Old 05-08-2008 | 08:32 AM
bikener
Default possible DIY?
So my clutch is starting to slip.. that sucks. I've go very little knowledge about clutch work but my dad sais he could probably do the labour. Would it be possible for two noobs (me and my dad) to replace the clutch in my 1990 accord if we did any required research for the job? How hard is it to replace the clutch?
Old 05-08-2008 | 09:40 AM
BlkCurrantKord's Avatar
Default RE: possible DIY?
Should be possible for both of you to do it granted you have all the necessary tools. Replacing the clutch is a fairly labor intensive job, you have to drop the trans.
Old 05-08-2008 | 01:55 PM
00AccordLX5spd's Avatar
Registered User
As BKC said, the entire transmission must be dropped/removed to work on/replace the clutch. The car will need to be lifted off the ground enough to get the trans dropped to allow access to the clutch. Unless you want to remove the engine instead...
Old 05-08-2008 | 02:19 PM
falkore24's Avatar
Dropping the tranny is a lot easier than pulling the engine.
Old 05-08-2008 | 03:29 PM
Registered User
ORIGINAL: falkore24
Oh really? **sarcasm**
Old 05-08-2008 | 03:57 PM
finch13's Avatar
ORIGINAL: 00AccordLX5spd
ORIGINAL: falkore24
I am going to be changing the clutch and flywheel here as soon as I get my exchanged clutch disc back from Fidanza. I can let you know how difficult it was to do. It's not going to be performed on a lift or anything, just jackstands and tools, FTW.
Old 05-08-2008 | 04:52 PM
Registered User
ORIGINAL: finch13
DIY with pics!! That would be a nice edition to the DIY section!
Do it or ban
Old 05-08-2008 | 04:55 PM
finch13's Avatar
I can try... my Grandpa gets fussy over wasting time though... wouldn't want to support those ricer hooligans! lol. I will see what I can do though.
Old 05-08-2008 | 05:10 PM
falkore24's Avatar
Don't get the camera greasy!!!
Old 05-09-2008 | 12:13 AM
But if you do, make sure you use windex cleaner and a Soft Cloth
Quick Reply: possible DIY?
