possible timing question need HELP
Old 11-20-2007 | 07:56 PM
toddyfresh's Avatar
Default possible timing question need HELP
I just replaced the motor on my 94 accord and changed the timing belt on the used motor i got. it had no distributor so i used my old one. I got the motor in tried to turn it over and it tries to start but wont. it sounds like ****. i cant explain the way it sounds but its like waw waw waw waw. i tried to explain. anywaysi replaced the timing belt same as it come off rotated it a few times and was still lined up. is it possible the distributor being in the wrong place can cause it?any help greatly appreciated
Old 11-20-2007 | 08:07 PM
nafango2's Avatar
Default RE: possible timing question need HELP
i would say check to make sure you have compression and ignition timing. It sounds almost like theres no compression + the starter is just spinning the engine.
Old 11-20-2007 | 10:04 PM
toddyfresh's Avatar
how wouldi check ignition i know motor is good it was running b4 pulled on old car
Old 11-21-2007 | 03:03 AM
Planefreak's Avatar
There are several things that could be screwed up or off:
You might want to line up the engine to top dead center and then check the alignment and make sure that the appropriate valves are open/closed.
I'm not sure how your distributor works but a lot of older honda's can only be 180 degrees off, but judging by the sound I don't think the distributor is the issue. Sounds compression related.
Old 11-21-2007 | 01:57 PM
toddyfresh's Avatar
i dont have a compression checker but i took the plugs out and put the wires back on and each cylinder blew the wires out so i was figuring compression was ok and even heard it running b4 it was pulled out of car and i purchased
Old 11-21-2007 | 05:32 PM
falkore24's Avatar
try again bro .... we're looking for 170-180 psi. Your engine could be rebuilt without piston rings and it will still blow the plugs off of the holes.
Old 11-22-2007 | 06:53 PM
toddyfresh's Avatar
I messed with firing order and it started for like 2 seconds and quit. it sounds like garbage for the little bit it was started. if the timing is off a little bit do you think that could cause it. i thought i did it right and i do know when i am lined up on crankshaft the 1 cylinder is at top caused i put a screwdriver in plug hole?
Old 11-23-2007 | 08:14 PM
toddyfresh's Avatar
Well I took the timing cover off ....again and i noticed that the camshaft was off say 1/4" (give or take) off to the right. i didnt check the balance shaft or anything else but with that being off a little would that still cause it to not run properly.
Old 11-24-2007 | 11:19 AM
Make sure your plugs firing order is correct, connect a timing light to #1, and check base timing while turning engine over. I suspect your base timing (distributor) is way off.
Old 11-24-2007 | 02:25 PM
sir_nasty's Avatar
If your plugs are out of order or your timing (camshaft/crankshaft) is out it will not run. if your camshaft was off 1/4" and your crank was at TDC then you've got to correct that before you do anything.
