Power steering lose at low speed.
Old 07-08-2013 | 12:29 PM
trucknut88's Avatar
Default Power steering lose at low speed.
I have a 1991 accord and the power steering drops out at low speed at times. I also notice the fluid comes out of the reservoir at times and looks foamy. Is it the rack or a bad pump. Also.. what is the component on the trans that power steering lines go to?
Thanks
Old 07-08-2013 | 12:58 PM
Foamy PS fluid is usually caused by air leaking in on suction side of the PS pump. There is an oring on the pump inlet fitting that is most frequent source of leak. Try replacing that oring.
dalkins1
05-14-2011 11:56 PM
irhunter
03-23-2011 05:49 PM
divaslone
10-28-2010 07:17 PM
HondaAccordNewb
10-18-2007 07:51 AM
wforbush
06-28-2005 03:00 AM
