Pressing lock button on the key twice and the horn stays on
On my 2003 Honda Accord if I press the lock button on the key twice the horn stays on.
I have to open the car with the key in the door lock then turn the ignition to on to stop it.
I checked all my door switches and tried to locate the hood switch but cant seem to find one. Is it possible the LX does not have a hood switch?
What else could cause this type of behavior? Is there a rest sequence I need to perform to reset the security system.
Thank you in advance.
Is your car a V6? If so, then it should have the factory installed security system. Only EX, all V6, and Canadian LX-G models came with the factory installed alarm. The security system hood switch is built into the hood latch. If the alarm goes off, it will continue for two minutes, then the system resets. To reset an alarming system before the two minutes have elapsed, unlock either front door with the key or the remote transmitter.
For models that did not come with the factory installed security system, it can be added on as an accessory. The security system hood switch is an optional extra to the accessory security system. These are the installation instructions for the add-on system and hood switch:
http://www.handa-accessories.com/accord/03-Security.pdf
http://www.handa-accessories.com/acc...HOODSWITCH.pdf
Normally, if any door, trunk, or hood (for systems with the hood switch) is not fully closed, the system is not suppose to arm.
It sounds like your system is arming and there is something triggering it.
PrettiBoiHonda
03-28-2012 11:39 PM
joysarkar
08-20-2010 12:20 AM
