primary hood latch will not lock
2002 accord
the primary hood latch will not engage automatically.
when i open the hood and close it, the secondary engages. the primary has a latch that is spring loaded and connects to the release handle in the car.
i have to move the latch manually to get the primary to lock. when i move it feels like there is grit binding it . but after i move it, the latch moves freely.
i cleaned it with carb cleaner and then wd-40.
still no luck.
Ideas?
thanks
still no luck.
Ideas?
thanks
Check whether release mechanism is repositioning (spring action) after release. If not, the return spring may be broken. The spring is on the hood latch end, but mechanism has a tamper guard that may make repair difficult. You will have to release the bolts to access the mechanism.
regards
regards
regards
regards
Sometimes corrosion can bind the cable in the sleeve preventing proper release/actuation. You may need a new actuation cable/sleeve. If you can reach the end of the sleeve you might try injecting some light lubrication down the sleeve and work the wire to loosen.
it is defininately the cable and has to be replaced.
any instructions/ diagrams on how to replace the cable? picking a new one up at honda this week.
thanks
You can download a 98-02 shop manual from the online manuals thread in the DIY section. It is an iso file, so burn it to a CD. It covers UK accords, but it should give you a good idea of how to change it out.
You will have to likely pull up the carpet on the driver's side to route the cable. Not sure exactly how it is routed to the trunk.
i have run into the same problem. its freezing here so i think the spring on the latch was frozen and just snapped in half. i was looking for the repair manual you mentioned above but i could not find it on the site.
could you send me a link? maybe im just being stupid...
thanks
