Pump noise on cold startup
Old 03-26-2013 | 09:23 PM
Hangfire79's Avatar
Default Pump noise on cold startup
2009 Accord V6, 33k miles. On a cold startup such as first thing in the morning or after my shift at work, I hear a somewhat high pitched noise which sounds like a pump cycling. It's been cold here and it's done it the last 2 days. Thanks for any help.
Old 03-26-2013 | 09:24 PM
Hangfire79's Avatar
It only does it for about 2 seconds.
Old 03-26-2013 | 10:09 PM
Old 03-26-2013 | 10:47 PM
Hangfire79's Avatar
Yup, almost identical.
Old 03-29-2013 | 08:46 PM
Hangfire79's Avatar
So it's the alternator?
Old 03-29-2013 | 09:02 PM
Alternator....I don't think so.
It is sounding more like the vtc solenoid to me. Cold start....hours of sitting and then "errr" on start. I've seen this on the 4cyl before. Need to check on the 6 cyls?
Old 03-30-2013 | 06:51 PM
Hangfire79's Avatar
What do you think it could be? I have no clue.
Old 03-31-2013 | 02:09 AM
It is a known problem with the vtc solenoid. Just search the web about this topic, because it has been covered.
Old 03-31-2013 | 09:55 AM
Hangfire79's Avatar
Thanks for the the replies
Old 03-31-2013 | 11:58 AM
I don't believe the V6 had VTC (Variable Valve Timing Control); so, the Honda technical service bulletin (TSB) for the 4 cylinder is not applicable to the V6.
cryptonate
11-12-2009 06:09 AM
ufosearch
03-02-2009 11:59 AM
gaugeman
03-10-2008 02:30 PM
farango
02-11-2008 09:12 PM
trukid21
03-06-2007 11:08 PM
