Pumping of brakes after brake job
Old 04-03-2013 | 09:04 PM
Hangfire79's Avatar
Default Pumping of brakes after brake job
Just got rear brakes on the back and the rotors lubed. Now it feels like the brakes are pumping as you slow to almost a complete stop. It may just be the transmission downshifting but I didn't notice it before. Of course I'm always paranoid after work is done. I thought the transmission disengaged when you stop. Any thoughts?
Old 04-03-2013 | 10:10 PM
The transmission doesn't "disengage" when you stop.
Is it a rhythmic pumping like once for every rotation of the wheel? Downshifting only happens 3 or 4 times while slowing to a stop. Brake pulsating happens a lot more than that.
Old 04-03-2013 | 10:29 PM
Hangfire79's Avatar
Yah, it feels sort of after every rotation. Like from 10-5mph to a stop.
Old 04-04-2013 | 08:07 AM
Can you try the handbrake to see if it pulsates? That will tell you whether it's the front or rear brakes doing this. If it's the rear brakes, which you just got done, then you can go back to the shop that did the work?
Try this:
https://www.hondaaccordforum.com/for...-rotors-27436/
driftdoggy
05-24-2013 12:16 AM
mdg
06-27-2012 09:01 AM
wapatano
08-11-2011 08:51 PM
dcsmith
03-21-2008 08:02 PM
SIXPAK GQ
08-31-2007 11:05 PM
