Put in new engine and now is rpm fluctuating
Old 10-24-2012 | 02:25 AM
corey246's Avatar
Default Put in new engine and now is rpm fluctuating
Okay guys so I put a new engine in my 95 Honda accord EX Automatic. I had an F22b1 engine and I put the same type back in. I kept my old intake and put new gaskets on the intake and exhaust. Kept my old transmission. Kept my old distributor, alternator, and power steering. So after it was all back together and on the ground I started her up and it jumped up to 3000 rpms and then started fluctuating from about 3000 to 4500. I turned off the car and noticed a broken Air change temp sensor. I got a replacement and now the car is jumping from 1500 rpms to 2500. When its in drive it wont go any lower than 3000 rpms and will fluctuate when im coasting down the road from 3000 to 4500.
After looking around i dont see any hoses undone or any sensors unhooked. There is no check engine light.
Any ideas?
Old 10-24-2012 | 11:12 AM
Vacuum leaks?
Air-pockets in the cooling system? Really, that can confuse the idle-control system. Open the heater to full-hot & bleed air from the bleed-screw on the thermostat housing.
Look in the DIY section for something about tightening the FITV (fast-idle thermo valve).
Then look in the DIY section for a post by me about setting the BASE idle and forcing the ECU to re-learn the idle.
Old 10-25-2012 | 07:48 PM
corey246's Avatar
Thank you for the reply. It was my intake. It wasnt tighten down.
MessAround
08-18-2011 08:13 PM
Flatline1121
06-29-2008 02:24 AM
HondaPhyco
03-04-2008 09:55 PM
AKcord
03-29-2007 02:44 AM
wietgr
12-24-2006 03:47 PM
