putting obd1 h22a into my 96 accord ex 5spd harness and ecu?
Old 03-05-2013 | 09:46 PM
h22a_turbo's Avatar
Default putting obd1 h22a into my 96 accord ex 5spd harness and ecu?
I am gettIng ready to put the engIne In I am unsure if what I have will work if not. What will I need? I have a harness and ecu from a 95 accord lx auto will this work
Old 03-06-2013 | 12:31 AM
You may need to keep your car OBD2 for testing purposes.
You may want to use the ECU from the 96 prelude. You might want to post in the engines forum. This area is geared more towards repairs. There are also forums out there that deal with swaps. The H22 swap is pretty common, so I am sure there is a way to keep it OBD2.
Old 03-06-2013 | 09:26 AM
h22a_turbo's Avatar
Thanks I will check out the engine section
skadank777
04-26-2013 06:54 AM
h22a_turbo
03-06-2013 01:56 PM
Bacondoggy
10-05-2009 11:27 PM
hitek85
02-12-2008 11:32 AM
spool666
02-02-2008 09:30 AM
