Question about 1992 Honda Accord EX
Hi,
I just recently bought a 92 Honda Accord EX from a private seller. I have had some questions about it, I may decide to post more in the future in this same thread (instead of creating a 100 of em ).
At the moment, I noticed that the car has a clutch pedal...but its an automatic? it has gears 1, 2, D3, D4, R and P of course. So, is this normal? is this how the stock version is? the clutch pedal is pushed all the way down I think, so you cannot even push it in. I am able to shift to different gears just fine without using the clutch.
I drive my car using D4. If I put the car in gear 1, it only goes to about 60 and thats it, and it makes a lot of noise at gear 1. At D4 its smooth fast and does not make a lot of noise unless I start going real fast.
RE: Question about 1992 Honda Accord EX
Your car is obviously a hermaphrodite, a very rare mutation.
Sounds likely that the car was originally a manual, but that at some stage it's had an automatic box put in, but they coudn't be bothered getting rid of the original clutch pedal.
60mph sounds pretty good for only 1st gear, I'll bet it's revving like crazy. Do you mean that the transmission is noisy in 1st, or that the engine is?
sheesh, I'm done ROFLMAO now....did the "private seller" install a TCU and do you have the gear lights in the dash cluster? or are you driving and the trans only shifts by default pressure?
My only guess of the situation is that some Mental Midget stuck an auto trans into a 5speed car. The complete VIN would tell the tale.
Sorry to hear that somebody stuck it to youlike that.
