Question about changing engine oil
When you change the oil, do you need to jack up both side of the car or just the side where the oil pan is located. I have 1 floor jack and 2 jack stand in my garage right now. I'm going to buy the washer, oil filter (and oil filter wrench if necessary) and the engine oil next week. Do I need to buy anything else for extra safety when it's time to jack the car up. My car is a 2005 Honda Accord. Thanks!
The front of the car has a center jacking point (flat rectangular spot) with an arrow pointing to it. This is where you place the floor jack to lift. I like to use a heavy duty floor jack rated for a higher capacity for safety.
Before jacking it up, place wheel chocks behind the rear tires. You can buy wheel chocks or use something like wood, bricks, whatever for help chock the rear wheels.
This thread shows pictures for your car.
https://www.hondaaccordforum.com/for...re-misc-35981/
I use Rhino ramps, Welcome to RhinoRamps® available at WalMart for around $29.. I also installed a Fumoto drain valve. www.fumoto.com Makes life simple. I also purchased a filter wrench at WalMart that slides on the end of the filter.
I drive the front wheels just a bit up onto some ramps. I only need the car to be about 2 inches higher than normal in order to get under there. You could drive up onto a couple pieces of wood, like 2x6? MAKE SURE IT'S SAFE & SOLID.
