Question about Struts, new tires, alignment...
93 accord ex coupe..............
i have new struts for the front and am getting 4 new tires....I am going to do the struts this weekend and then go put on the tires, I know it's going to need to be aligned, my question..............
if i do the rear struts next month, do i have to do another alignment???
thanks for your answers!!!
Unless I'm missing something or unless the previous alignment was done with the struts bent or springs really sagging, I wouldn't think the alignment would be affected by the new struts. Upper and lower ball joints, radius rod bushings, control arm bushings and tie rod ends would have a much greater impact on alignment. I think struts would have to be in really bad shape to influence alignment.
I think the front struts on a 93 do not contribute to the alignment. If the control-arm balljoints are separated at their tapered studs (rather than other bolts), then the alignment shouldn't change.
Another suggestion is to wait a couple hundred miles for all the new parts to shake & settle. THEN get an alignment.
Hi Jim :)
