Quick help for this one. Inline transmission filter.
Old 03-25-2013 | 02:11 AM
AccorDats's Avatar
Default Quick help for this one. Inline transmission filter.
Greeting HAF!
After replacing my inline trans filter, i am not sire if i pit the new one correctly. I have photos for you guys to look at. Please let me know if the flow is correct.
Thank you once again HAF.
Old 03-25-2013 | 08:40 PM
I can't find a good diagram for the 5th gen 4 cyl auto to be able to tell?
I found something for the 6th gens but I'm worried it is not good info.
Can you remove the filter and crank then engine over - disable fuel or spark so the engine will not stat and see which hose "pushes" fluid out?
Also, I can't tell from the pic's but I hope you used hose that is rated for trans use....Regular fuel line hose SHOULD NOT be used for this.
Attached is the flow for a 6th gen (98-02) 4cyl auto.
Attached Thumbnails Quick help for this one. Inline transmission filter.-6th-gen-trans-cooler-lines.jpg
lhiyama
03-09-2012 12:52 AM
22psi
04-04-2008 01:26 PM
HORSEPOWERJUNKIE2007
03-08-2008 01:45 PM
purify
07-07-2006 08:35 PM
Billdo38
01-06-2006 06:39 PM
