rack and pinion
rack and pinion
I have a 90 honda accord ex, I have disconeted every thing from the rack and pinion, but I can not take it down the steering shaft will not allowe it to move, I have also dsiconected the shaft from the steering wheel.
did you remove and loosen the 2 ,10mm bolts at the bottom of the steering column??
there is a black cover with clips at bottom of steering cover it wraps around column,, you need to remove it, there is a joint that connects the column to the p/s rack,, remove the lower bolt, loosen the top bolt and slide the joint upward away from rack..
piece of cake......... while you hold the rack,,just grab one side of the tie rod and pull it all the way out ,,i think it is all the way out to the rt side ( passenger),, it will then clear ,,
Up late there old man...WheelBrokerAng
I have tried that, but there is a welded bracket on both side that won't allowe clearence for the tie rod to come down. I have taken down the muffler, all the bolt for rack and pinion, the fluid lines, the bolt from the steering colum, is there anything else I'm missing? there is a bolt on each side holding part of the frame do I have to remove them?
liam71234
10-07-2007 09:54 AM
