Radiator/Transmission Problems
Old 12-20-2006 | 08:59 PM
dplampe
Default Radiator/Transmission Problems
I have a 95 Honda Accord 4dr LX with the 4 speed automatic transmission. I had a crack in my plastic radiator so I changed it out with a steel radiator. I also changed the thermostat while I was at it. My transmission was working fine up until the swap, but now it will not shift out of firstand sometimes it won'teven go into gear. I have already tried changing the transmission fluid, and I read in another thread to check the solenoids and the line pressures. How do I check the line pressure and solenoids? Any help would be greatly appreciated, even if you can just point me in the right direction. Thanks.
Old 12-21-2006 | 03:21 PM
ohccord's Avatar
Default RE: Radiator/Transmission Problems
Since everything else has been checked or changed, I would check the A/T Control Unit. You have symptoms as described here. http://techauto.te.funpic.org/transmission.php"The trans won't shift into gear or may get stuck in a certain gear."
BigRoach
06-03-2013 02:54 PM
Novaknowledgenow
05-30-2013 09:58 PM
hmr
03-28-2012 11:49 PM
quassu77
10-06-2011 12:30 PM
KimberlyC
04-16-2006 12:51 PM
