Radio and AC
Radio and AC
2003 Accord LX- the radio started going in and out (the screen would go blank, speakers not working). Like there was a short. The time would also pop on and off. But then it would just come back on out of the blue. What is the problem. This is the original radio and speakers. Also is this in any way connected to the AC?
Originally Posted by Chemist
the ac does not work. It blows hot air on the right side only. The drivers side works fine
I had a 2003 LX and it didn't have separate temperature for right & left sides. So it won't have separate blend-doors for right & left side.
I think the AC cooling only one side can be caused by low refrigerant charge.
OP check pressure on a/c system if low find leak and fix then recharge. Do not add Freon blindly.
