radio code
there is a write up on the DIY section on how to get the serial # ,,,it does not work on all years ,,,,,,Once u have the serial # it is easy,, call the dealer, verify proof of ownership and they will give you the radio code
Re xp190 . Your second way worked . Thanks . I did not lock my 5 digit code though .
Here are are the steps. 1999 Honda accord EX. V4
1)Radio locked after battery change.
2)Lost code and could not recollect serial number .
3)Found a 10 digit alphanumeric number in the glive box (small white sticker)
4)Called the dealer directly (he gave me the 5 digit code w/o asking any details like VIN# etc . he just took the Serial #)
5)Tried putting in the code ..it wouln't work .
You need to hold each number for roughly a second and keep holding on the last number of the code until the radio starts playing . I did this in the 9th attempt ..just puttoing the code won't work .. YOU HAVE TO KEEP PRESSING THE LAST NUMBER .
Or you could try here, I haven't personally tried it, but it looks promising...Given that you're actually the owner of the car
https://radio-navicode.honda.com/
