Radio Won't Work
Radio Won't Work
I am in need of answers. I recently entered the code to my 92 Honda Accord EX, the word code went out and the beep sound sounded. Afterwards my radio went blank and would not play. I disconnected the battery and started over from the beginning and the same thing occurred. After the code was entered and the word code went out, the radio would not play. The antenna would go up when the radio is turned on but there is no sound and nothing coming up on the radio.
Welcome to HAF!
You placed this in the wrong section. But I am sure that a Admin could relocate it in right location. I am pretty sure that you should have asked this in the section General Tech Help.
So back to your problem,
Did you put the code in one time, or did you have to put it in more than one time??
It sounds to me like you put the wrong code in multiple times and its in a lock down mode.
Double check the code from the owners manual to make sure that you are putting the correct one in.
togles
05-09-2017 07:32 AM
brownaddesign
02-01-2013 07:17 PM
sirtwist2
08-31-2012 11:03 PM
taylor1321
07-29-2008 11:26 PM
